Almost a crash
1 Attachment(s)
I have a new plane up and running. It's the H9 Cap 232 25% with MDS 148.
My enigne is well broken in. I flew it on a Joss Stick for about 2 or 3 gallons before putting it on the Cap. My muffler came loose in flight and my engine started running like $h*t. I came in for a landing, but the engine wouldn't slow down enough to land. I think the lack of backpressure wasn't allowing the engine to idle down slow enough. I decided to abort the landing and try to throttle up for another pass. I wasn't getting too much out of the engine at this point. it was gurgling and farting alot. I banked hard left and did a quick circle and got lined up to land again, only in the opposite direction. I pulled the trim tab on the throttle all the way back to kill the engine. I landed deadstick and rolled to a stop. I don't think my engine would have pulled the plane all the way around the pattern for another landing attempt. I believe that my quick thinking and gentle thumbs saved my plane from an early death. One of the guys in the pits said to me that it was a pretty exciting landing. I told him, "You should feal my heartbeat right about now." I'll bet my heart was pounding away at about 160 beats. The Cap will fly again another day. |
Almost a crash
Good save!!! I had a similar experience with my Ace Extra 300. It was at an airshow, and overpowered with a G-62 (the same combo separated the tail in flight once.. the balsa split down the middle, the glue joint didn't fail, the wood did!! It was flown with a G-38 before and worked well). The throttle stuck wide open (flutter city) so I flew it around knife-edge to keep speed down a bit, lined up on the runway and landed on the mains wide open and fed in some down elevator and the prop hit the ground, killed the engine, and coasted to a stop...
| All times are GMT -8. The time now is 05:08 AM. |
