Diversity Receivers
NC
Diversity Receivers
I just got a Diversity receiver from Draganfly, which is a yellowjacket, but it isn't picking up any signal! They told me there are a few firmware issues and gave me the number to the manufacturer. We haven't' figured it out yet, but do you guys have any experience with this unit? They also said this was the new version of the same receiver, but just in a smaller housing.
I'm getting much better video with the SAVS boom, and it really helps out with orientation! I'm getting more confident when I'm up high! I'd post some video, but haven't' found a good movie editor program any recommendations?
NC
RE: Diversity Receivers
I have now sent the unit off for repair.....I didn't get the full idea of the problem, but it has something to do with amplifiers? It is going to be turned around in 24 hours and it went direct to the manufacturer in Colorado. He says it will actually work better when I get it back than originally designed.
NC
Got the receiver back and it is now working......well after you reverse the yellow/white RCA's that is. Don't know why you need to do that, but it at least works.
now what antenna have you guys tried? Are the patch antenna's the best? I have the right patch and a omnidirectional 2.4ghz antenna hooked up. Would I be better off getting the left patch?
When I'm up in the air I have no reception issues, but if I'm "low" 20ft or less and fly sideways I lose signal sometimes or it has static.
VA
Bill Strong at BWAV had something written on his site....don't know where now offhand. He stated you actually get better reception if you put the antenae on the ground....somehow if filters out side noise and interference but still gives the range and coverage you need. Might be worth trying.
Allen
Allen
GA
That's true AeroRecon. I have gotten the best results with my antennas lying on the ground with one facing straight up and the other at a slight angle just under 45 degrees. The antennas also don't need to be near any metal enclosures or fences.
NC
ORIGINAL: Sky High
NC
Here is a quick video of my draganflyer with the LED lights. Landed harder than normal, but wasn't too bad.
http://rcuvideos.com/item/F84NPBWWQMRV86R1
