Draganfly Innovations Products Discuss all the Draganfly Innovations Products in this forum
motor replacement
Old 07-22-2007, 01:29 PM
msarid
Default motor replacement
Hi
If I have to replace the motor can I use the upgrade motor to get more power or should I stay with the standard motor?
Regards
Moti
Old 07-22-2007, 01:54 PM
Old Man Mike
Default RE: motor replacement
ORIGINAL: msarid
Hi
Regards
Moti
You have to replace all the motors, not just one. As long as you do that, you will be fine with the HD motors. Be aware that the HD motors do not start up as slowly as the regular motors. You have to quicky push up the throttle a little and then back down to get all motors rotating. If you throttle up very slow, one or two of the motors will not start rotating at the same time and the DF will take a hard lean against the ground.
Mike
