E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Battery Info
Old 05-23-2005, 07:37 PM
bbellfly
Default Battery Info
I have purchased a Sig Kadet EP. Sig's baby Kadet, it's electric powered. I am doing research on batteries to determine what battery to use. The assembly manual recommends a 7 cell 1100mah Nimh battery pack, in a flat configuration, with a Tamiya plug. The recommendation does not mention voltage.
New to RC and Electric RC, I do not know what battery to purchase. I will be running a HiTec Electron 6Ch FM DC RX 72Mhz:RCD/FUT, with HiTec HS 55 micro servos. The supplied motor is a 7.2 volt Speed 400, an upgrade over the normal speed 400 can motor. The manual mentions this, so I included it.
Any help will be greatly appreciated!!!
Old 05-23-2005, 09:28 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default RE: Battery Info
Actually, the recommendation does mention voltage, in the form of cell count. A 7-cell NiCd or NiMH pack will have a nominal voltage of 8.4 Volts; each cell has a nominal voltage of 1.2 Volts. Doesn't matter how big or how small, a 7-cell pack will always have a nominal voltage of 8.4 Volts.
I would get at least an 8-cell pack of 1100mAh NiMH cells. More voltage means more power, and it might be marginal on power with a 7-cell pack.
You can get the exact pack you need at many online battery vendors. I would recommend a pack made from KAN1050 or GP1100 NiMH cells from a vendor like Cheapbatterypacks.com.
Old 05-24-2005, 05:37 AM
Red Scholefield
Banned
My Feedback: (9)
ORIGINAL: bbellfish
Get rid of the Tamiya plug - voltage drop in these is enough sometimes to actually melt the plug. Use Sermos or Deans Ultra.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
