E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
nimh battery upgrade
Old 05-24-2005, 03:00 PM
lillbill11
Default nimh battery upgrade
HI EVERYONE:
I HAVE A GWS TRANS-QUAD AND I'M USING ( NIMH AAA 750 MAH 8.4 V ), CAN I
SWITCH TO A ( NIMH AA 1600 MAH 7.2 V ), TO GET MORE POWER, AND LONGER FLYING TIME.
IF NOT, WHAT CAN I GO TO.
THANKS GUYS
YOURS TRULY BILL GRAY
Old 05-24-2005, 03:51 PM
-pkh-
-pkh-'s Avatar
Default RE: nimh battery upgrade
You're staying in the same batt technology (NiMH), and moving to higher current discharge cells (which will have more weight for a given capacity), so your AAs will likely be more than twice the weight of the AAAs. How that will translate in to performance and flight time will be hard to say. You may actually reduce your max rpms since you're dropping a cell as well.
Going to LiPo cells would be the best upgrade from NiMH cells, IMO...
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
