Voltage drop in Ni-MH
Hi
Can anyone tell what the maximum voltage drop should be in a 8.4v 730Mah AAA battery pack should be I am pulling about 8 amps at full throttle.
RE: Voltage drop in Ni-MH
I thinks ots 8 amps its for the Thunder tiger super cub. I have my ESC set to cut at 5 volts becuase at 6 and 7 volts it cuts the motor. The cub has a 370 motor geared to 2.67:1 and usin i think a 6 or 7 inch prop i may be wrong
Aidan
Aidan
