Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
Reload this Page >
amperage ? about new duratrax ice charger
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Old 07-27-2005, 03:55 PM
evlfkr
evlfkr's Avatar
Default amperage ? about new duratrax ice charger
I have a 12v power supply for my home that has a 3amp continuous and 5amp surge will this power the duratrax ice charger while charging li-po?
Old 07-27-2005, 09:06 PM
woodduck-RCU
Default RE: amperage ? about new duratrax ice charger
It really depends what you are charging, if are charging a 3 cell lipo pack at 2 amps or a nimh at 1.5 amps you will probably be ok.
But you won't be able to charge 10 cell packs. The minimum stated input for the chargers is for heavy charging conditions.
Wood Duck
Old 07-28-2005, 08:13 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Ah, this is a perfect time to introduce the "mkirsch1 formula" some of you may be familiar with from that "other" site
This is a formula for sizing a 12V power supply based on the size of the pack you want to charge, and what rate you want to charge it:
Power Supply Amps = <# of NiCd or NiMH cells> * <charge rate> / 6
Let's say you want to charge 10 NiMH cells at 6 Amps.
Power Supply Amps = 10 cells * 6 Amps / 6 = 10 Amp power supply
