E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Help
Old 01-08-2006 | 01:51 PM
Default Help
I have a 3 cell 830 mah lipo and it wont charge. I checked thbe voltage and its low? If a battery becomes discharged to low will it not charge?
Old 01-08-2006 | 02:05 PM
My Feedback: (27)
Default RE: Help
Becomes garbage. I learned the hard way. I left my switch on from my plane when I returned from flying voltage went to low and I had to throw the battery out.
Old 01-10-2006 | 12:46 AM
jdetray's Avatar
Default RE: Help
A lipo battery should never be discharged below 3V per cell. That's 9V for a 3-cell pack. If your pack measures less than 9V, it was over-discharged and may be damaged.
If the voltage is too low, many lipo chargers will refuse to charge the pack. This is a safety feature, since it can be dangerous to charge a damaged pack.
- Jeff
Old 01-10-2006 | 04:24 PM
Default RE: Help
If you know of anyone who owns a Triton charger it may be able to save the pack. I've saved quite a few batteries for people who's volts where down in the 4.00 volt range. Hopefully it hasn't been too low for too long. Give it a shot.
Bevo
