Battery or charger problem!!!!!
Hope someone can shed some light on this problem. Here we GO. I just got my Elestric Heli together and wanted to try out.Here is the Problem ,I got 5 battery Packs all of which I used this fall in my airplanes,well I went to charge one up and couldn't get it over 4.9 volts hmmm
so I tryed different charger 4 in all with all 5 packs. Can't get any over 5.0volts.Acouple chargers a 110 volt and 2 run off battery in my car. WHATS GOING ON!!!!!!!!! never had any trouble before.[:o] Thanks for any help Kenny |
RE: Battery or charger problem!!!!!
Kenny, how or with what are you measuring the packs voltages ?
I am checking the voltage of the packs with a VOM meter whcih should read the voltage of the pack or a little over if fully charged.
kenny |
Kenny, Lets figure this one out, first, make sure the VOM is good, take it to a known voltage source and make sure it reads ok, try a known good battery. Hey, if you can, we can try MSN messenger and I will walk you through the troubleshooting.
:eek: Well a little egg on my face[:-] . I had a couple problems and that was what was confusing me. (1) My vom meter was on the fritz (2) the heli is new to me and the gears were meshed a little tight that put drag on the motor and would eat the battery up quickly and (3) the brushed on the motor were wear down and causeing it not to run right.
Well I think I got her under control.........Thanks...........Kenny:) |
[sm=thumbup.gif]
| All times are GMT -8. The time now is 06:11 PM. |
