RCU Forums
-   E-Flight Power Sources (https://www.rcuniverse.com/forum/e-flight-power-sources-126/)
-   -   which battery pack??? (https://www.rcuniverse.com/forum/e-flight-power-sources-126/2920319-battery-pack.html)
vatechguy3 04-27-2005 05:00 PM
which battery pack would i need to use with an eflite 400 motor, 6.6:1 gearbox and a 12x6 prop???
i'm thinking i would need a high discharge (15C) 2000mah, 3 cell lipo.
is this right???
what would happen if i use my 1500 mah, 8C, 3 cell lipo??
thanks
tony
exeter_acres 04-27-2005 05:05 PM
RE: which battery pack???
depends on the plane I suppose....and I am not sure the exact ratings of that motor
the 8c might work.... run the numbers through Motocalc or pick up a Whatts up (or similar) I didn't want to either, but I'm glad I did....
I use Thunderpower 1320 3S1P packs with good luck and a polyquest 1500 pack (the polyquest is quite a bit bigger but weighs about the same..)
I use this in 3dfaomy style planes.....
vatechguy3 04-27-2005 08:17 PM
the plane would be a hanger 9 mini funtana.
the 400 motor is a 4200kv.
i currently use the 370 motor, which is 4100kv.
what is motcalc??
tony
