RCU Forums
-   E-Flight Power Sources (https://www.rcuniverse.com/forum/e-flight-power-sources-126/)
-   -   battery charge error - any advice? (https://www.rcuniverse.com/forum/e-flight-power-sources-126/4183255-battery-charge-error-any-advice.html)
sachin998 04-19-2006 01:57 AM
Hi
I have a problem and was wondering if anyone could offer some advice.
I connect my 1250 - 3s LiIon pack into my Swallow charger. It puts in about 600-700 milliamps and the charger cuts. Then I plug the pack in and I get about 30 seconds before the battery dies.
Any ideas what the problem is?
thanks
Matt Kirsch 04-20-2006 01:05 PM
RE: battery charge error - any advice?
Too many variables at this stage of the game.
First thing I'd suspect is that one or more of the cells in the pack has gone bad. Before you charge it again, you need to measure the voltage in each cell separately. Charging it again could cause it to burst into flames if there's a dead cell, and the charger is overcharging the remaining cells in the pack. Remove the shrinkwrap if you have to. The cells all have to have roughly the same voltage to a tenth of a Volt, and they all need to be above 3.0 Volts per cell.
Have you successfully flown this aircraft with these pack(s) in the past? How many flights have you gotten? What is the power system you're using? How many Amps does it draw? How agressively do you fly the aircraft?
