Astroflight Wattmeter
Anyone,
Can you explain to me how to hook up my new Astroflight Wattmeter so I can measure power with different battery and prop configurations? I've connected the battery -3c 1500 lipo, to the source cables on the meter and the speed controller(which is connected to the motor) to the load cables from the meter, but, how do I connect the setup to the receiver so the speed controller works with the transmitter? Any help would be greatly appreciated. |
RE: Astroflight Wattmeter
Sounds like you have most of it right...you just need to plug the 3 wire lead (that looks like a servo lead, with the servo connector ) from the ESC into the throttle channel of the receiver.
;) Thanks - with your help, I was able to figure it out and it is working great. Thanks again for the help.
Glad to help!:D
| All times are GMT -8. The time now is 12:07 AM. |
