ParkZone lipo charger...
I have a F27C Stryker with the 2200 lipo & charger/balancer.,, I was wondering if it is possible to use this charger/balancer to charge my TP 2100 (adapters or the proper wire conection)?? This should work with the right conection.. any info would be greatly appreciated..............
Thanx..... |
RE: ParkZone lipo charger...
The balancer leads look to be of the same wire combo on my Apogee 2170. will this work? the plug fits..
thanx.. |
I believe the polarity of the Parkzone balance lead pins vs. the Thunder Power pins are reversed. I would suggest using a voltmeter and checking the polarity of the pins on the Parkzone and Thunder Power packs to confirm. There are 4 pins on the balance plugs and putting a voltmeter across any 2 pins that are next to each other will give you the voltage of a cell. Just check the same pins on each plug and it will tell you whether the polarity is reversed.
