replacing a lipo balancer plug
Hi,
I recently bought a TP-205v balancer Now I noticed that the plug that was already fitted on my lipo does not match the TP balancer. So I bought TP 6 pin balancer connectors @ Draganfly. But now I need to know how to connect the new connector. Who can help me with this or who has a voltage schema? I have a 4s3p and a 5s3p I suppose that I cannot cut of the old plug and connect the TP plug at random. Thanks in advance Eddy |
RE: replacing a lipo balancer plug
You could look for an adapter that would make the plug work with your TP charger, or you could follow these instructions carefully and attach your own plug.
http://www.rcuniverse.com/forum/m_5676541/tm.htm Can't you just clip the incorrect plug end off of the battery and, using those leads, attach the TP plug? -Erik |
| All times are GMT -8. The time now is 05:18 PM. |
