Is My Battery Pack Toast ????
I accidently shorted out the plug on my 3S lipo battery. When I put it on the charger it would not charge because 2 cells are 3.10 volts but the third one is only 0.23 volts [:o] Is there any way to bring this cell back or is the pack finished ??
RE: Is My Battery Pack Toast ????
Charge it as a Ni-Cd at C/10 and watch the low cell, it may come up. If it doesn't you could probably salvage the two good ones for a 2S pack. Keep an eye on it at all times when doing this.
If the voltage measured at the discharge connector is about 6.5 then it is probsbly a goner. If the voltage is 9.5 then maybe the balance connector has open circuit/bad connection only.
ORIGINAL: Red Scholefield Charge it as a Ni-Cd at C/10 and watch the low cell, it may come up. If it doesn't you could probably salvage the two good ones for a 2S pack. Keep an eye on it at all times when doing this. Thanks ............... |
ORIGINAL: Don M. ORIGINAL: Red Scholefield Charge it as a Ni-Cd at C/10 and watch the low cell, it may come up. If it doesn't you could probably salvage the two good ones for a 2S pack. Keep an eye on it at all times when doing this. Thanks ............... |
I guess I'll give up before I blow myself up. I cannot charge through the power plug nor can I get any voltage reading through it. I took it apart and I can only get a reading on one wire on the little circuit boad and that is 3.70 volts. I guess I shorten out / burnt the circuit board. Not worth blowing something up for a used $45.00 lipo :eek:
Thanks for trying to help. |
Hi Don, I had a similar problem with a Kokam 3s 4A pack first of all use a stand alone balancer
then set your li-po charger to two cells and charge watching carefully the balance should prevent the other two cells that are at the correct voltage from over charging when depending on your charger the pack voltage reaches between 8.4 - 8.6 v stop charging and re-set your charger to 3 cell 11.1v keeping the cell's connected to the balancer and your charger should now see the pack as a three cell and start charging, the balancer should prevent the other cell's from overcharging when you have finished this procedure cycle the pack two or three times using your balancer before you fly the pack checking that after each cycle the pack is holding a suitably usable voltage i.e leave maybe a 24 hr period in between each cycle , It may at first glance seem complicated but its not really, Do Not do this if you do not have a good Li-xx balancer, also I have never used a normal nicad charger on li-po's but I would not recommend it I might be wrong and those that have posted before me telling you to do this might know more than me but I would not use a standard charger on my li-po's, I really hope this helps there's nothing worse than a self inflicted mistake, we have all done it your not alone, keep smiling and keep having fun in this great hobby, James.;) |
The lipo is long since gone to battery heaven. I just didn't think it was worth having the thing blow up in my face for a used $45.00 battery. I did learn not to short out the cells on a lipo battery though [:o]
