Charging Lipo lower rate.
Hi,
I have two chargers that are connected to a 3A power supply, so I can't use both full charge (2.5A each). I want to charge two 3S 5Amp Lipo (one for each charger). Does it make any problem if I charge them at 1Amp rate ? (time is not an issue). Thanks. Alex. |
RE: Charging Lipo lower rate.
ORIGINAL: alexandre Hi, I have two chargers that are connected to a 3A power supply, so I can't use both full charge (2.5A each). I want to charge two 3S 5Amp Lipo (one for each charger). Does it make any problem if I charge them at 1Amp rate ? (time is not an issue). Thanks. Alex. |
Thank you :o)
