BANTAM or HYPERION help me decide
Guys, I need a charger for 6S
I am planing to fly a Trexx 500ESP with two 3S 3,000 mah packs and I want also to charge both pack at the same time. Whats you advice me to get. HYPERION EOS0606I AC/DC BALANCING CHARGER 6S, 6A, 50W ($139.95) OR BANTAM e-STATION BC6 AC/DC BALANCING CHARGER ($169.00) THX Isaac |
RE: BANTAM or HYPERION help me decide
Here is what I do with my xSxP packs built from 3S1P packs: Separate the 3S packs. Check the voltage, adjust to the same (+-0.05) by charging the lowest 3S packs a little. Then charge them in parallel as a 3SxP pack. Use a balancer for each 3S1P while charging. The charger will go 8 amps, might as well use it.
| All times are GMT -8. The time now is 03:10 AM. |
