RCU Forums
-   E-Flight Power Sources (https://www.rcuniverse.com/forum/e-flight-power-sources-126/)
-   -   paste (https://www.rcuniverse.com/forum/e-flight-power-sources-126/9972593-paste.html)
hawkman-RCU 08-31-2010 06:31 PM
paste
hey guys,
i buy alot from rcdude.com and there is a item im not sure about. there is a product he sells called solder-it aluminum/pot metal solder. i know long product name.
it says that it is a solder paste with flux mixed in. anybody have a idea what or how it is used.? thank you.
jdetray 09-01-2010 09:02 PM
RE: paste
Normal solder intended for electrical soldering won't work on aluminum. So if you wish to solder aluminum, you need a special solder, such as the Solder-It Aluminum Solder Paste.
Lipo batteries often have aluminum tabs, so if you want to solder to lipo tabs, that's one possible use for the Solder-It product.
- Jeff
hawkman-RCU 09-01-2010 10:43 PM
RE: paste
hey jeff.
thanks for your reply.
