Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
Reload this Page >
GY 520 installation on the Blade 400
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 10-31-2010, 03:51 PM
tandem4
Default GY 520 installation on the Blade 400
I purchased a GY520 gyro and S9257 servo combination. The enclosed booklet form Futaba is not very clear where the red and black leads included must be inseted into the plug on the wire lead. The lead from the servo position is clear as there is only one opening. Also where must the leads from the gyro be pugged into the stock Spektrum receiver.
See the picture of the plug as installed on the Blade 400 attached. Note the two openings facing upwards.
Also is there any place where I can find the setup parameters for the Gyro with a stock S[ektrum receiver on the Blade 400.
Old 11-01-2010, 09:30 AM
Rob2160
Rob2160's Avatar
Default RE: GY 520 installation on the Blade 400
ORIGINAL: tandem4
The full lead from the gyro should plug into your rudder channel on the Spektrum
The lead that has only a single wife should plug into channel 5 (for use with your gyro switch)
The servo then plugs into the opening as you described..
Hope that helps.
