MSR X
RE: MSR X
unfortunately after a month of trying everything i came to a conclusion that the msrx is buggy and no amount of mix can copensate for the fact that it resets the swash plate on rudder input.
What i mean is that in hover you have 0% aileron. on slow turns you have 10% aileron. On faster turns you have 20% aileron. etc.
In all these situation, the swash plate levels to 0% on rudder input
So the amount of mix you need in every single situation is not constable. So no amount of mix will be able to provide a stable all around flight.
I bought the msrx because it is supposed to be a good "teacher" for moving on to bigger hellis. But instead of learning to flight, you just concentrate on learning to overcome the as3x commands that you don;t want.
I also bought the dx7s for the mix (I didnt need any d/r or expos on the stock Tx) and it also now is useless.
They should come with a v2 version asap that leaves the swash plate alone when you want to rudder
