How to remove flybar from blade450
Had my first crash, after about 15 flights, learning to hover. My copter hit the fence. The wooden blades did not shatter, but the coating did come off near the end, bent the flybar, everthing else seems fine,but how do you get the flybar out? Got it most of the way out, but the rest will not come out.
Undone the allen screws on the flybar each side, and one blade paddle, so hoping to pull it through? what am I doing wrong? does the center screw also need to come out? Can get it get flybar almost to the thread, but seems hard to get the rest out?
Do I use pliars, or something to pull it through?
RE: How to remove flybar from blade450
Got it out, was a bit of a rough piece on the shaft, sandpapered it out and managed to pull it out, the tick will be to get it back in again, without also pushing out the little bearings while pushing the new shaft in. I noticed on one side a tiny looks like copper washer, or spacer, but none on the other side, or have not come accross it on the other side.
My first crash and hopefully a replacement of the blades, and flybar and will be back up flying, but not going for the wooden blades, the coating they put on them peals off, or mine was, so going to replace with carbon fiber blades.
Seems I lost one of the small copper stepped washers that go in front of the bearings in the seesaw assembly, must have lost it when I pulled out the flybar shaft, so do you know what part I need to order, or seesaw bearing set, which I pesume would have the 2 copper washers.
found the spacer, but when I spooled it up, with no blades, or flaybar, looks like the main shaft is bent also.
