Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
Reload this Page >
Share Futaba 9c settings for Blade CP Pro
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 01-06-2007, 11:16 PM
  #51
xgiacox
Default RE: Share Futaba 9c settings for Blade CP Pro
Parameters work great.... I am new at Heli's and the Blade CP Pro is my first. I added a Heading Lock Gyro. (E-flite G90) I was able to adjust the gain remotely with the Eflite transmitter. How do you do that with the 9C?
Thank you in advance
xgiacox
Old 01-08-2007, 03:00 PM
  #52
wingsman
I've just got a blade cp pro over the holidays. I would like to use my Futaba 8U. Would most of the 9c settings work as I'm not familier with it.
Thanks.
Old 01-08-2007, 03:44 PM
  #53
wingswest
wingswest's Avatar
xgiacox
I would check in the manual it has an entire section on that.
Old 01-11-2007, 10:51 PM
  #54
SSGSPEEDMAN
ORIGINAL: wingsman
Thanks.
Anyone have a clue?
Old 01-13-2007, 05:12 PM
  #55
tppjr
ORIGINAL: WilsonFlyer
I got my G90 working too. I set CH 5 to VR-B and reversed CH 5. Works JUST like the original TX with the G90 except it's on VR-B now.
Now if I could just figure out the helicopter equivilents of airplane dual-rates, I think I'd have this Pro where I could tame this beast. Any ideas?
How did you get CH 5 set to VR-B for the G90? Under Gyro Sens the variable switchs are not available for me. I have a 9C also. It is brand new to me so I must just be missing something but can't seem to figure out how to set up the gyro with it.
Thomas
Old 01-13-2007, 11:42 PM
  #56
Enticer
I would like to know also.
Old 04-13-2007, 06:39 PM
  #57
Georges Payne
ORIGINAL: tppjr
I'm new at this, first heli, first serious computer radio, so I don't know if I did it the right way, but it works. I set up channel 5 by going through Model/Basic/AUX-CH.
Only problem I encountered is to get the same swash plate position than with the stock Tx with the right stick in neutral, I had to set the Subtrims like this,
AIL : +59
ELE : -60
PIT : 0
and it troubles me because it seems a lot to me.
Old 04-15-2007, 08:44 AM
  #58
Enticer
Georges, those figures are not really high. When I had my blade i had the subtrim on a couple channels up around 80 and 90. Just adjust the subtrim until you get the servo arms at 90 dedrees.
Kevin.
Old 04-15-2007, 09:10 AM
  #59
Georges Payne
Thanks, I played a little with the servo pushrods and I was able to reduce the amount of sub trim required, and everything seems to be working just fine. Those little machines do take a lot of loving care!
Georges
