Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
Reload this Page >
Can a different transmitter be used with the blade CP?
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 10-19-2006, 12:22 PM
mbart99
Default Can a different transmitter be used with the blade CP?
Can a different transmitter be used with the blade CP? I would like to use a different transmitter with a blade CP so I can dial in exponential throw.
Does anyone know if you can change a reciever crystal and make it work with a Futaba or JR helicoper radio?
Thank you,
Mark
Old 10-19-2006, 01:01 PM
Mochaboy
Default RE: Can a different transmitter be used with the blade CP?
It's a negative shift receiver, so it's compatible with a Futaba Tx...
Old 10-19-2006, 01:52 PM
Tall Paul
ORIGINAL: Mochaboy
If the transmitter has CCPM programming.
Old 10-19-2006, 02:30 PM
jent
futbaba or hitech are the only transmiters I am aware of that can work stock with the blade....just so long as it has ccpm. I personally use a futaba 7CH with my heli and love it.
Old 10-19-2006, 04:15 PM
duaneh1
I use the optic 6 and love it. With spectra module you don't even need to get a crystal for the blade rx, just dial-in the channel and go.
Old 10-20-2006, 06:44 AM
HeliTB
HeliTB's Avatar
duaneh1...I use a Optic 6 as well. Do you mind sharing the following settings:
CCPM Mixing -> Swashplate % (all 3)
REVO Mixing -> R/U and L/U
Throttle Curve
Pitch Curve
Old 10-22-2006, 07:36 PM
FREEBIRD
I use a 6EXHP, and a short Rx crystal in the 4&1, works great, really smoothes it out
Old 10-25-2006, 06:58 AM
mbart99
Thank you for the information
Mark
Old 10-25-2006, 10:03 AM
orlbuzz
orlbuzz's Avatar
duaneh1,
are you saying that you don't have to change receivers? I don't think that's what you're saying, but just want to clarify.
orlbuzz
Old 10-25-2006, 10:35 AM
HeliTB
HeliTB's Avatar
orlbuzz...If you have transmitter that has spectra module or has the capability to change channels. You can dial the frequency the stock rx is using, so you don't have to buy an additional rx. My Hitec Optic 6 has such a module.
BTW: The stock rx in the Blade or HoneyBee are negative shift, thus can only used with Futaba or Hitec transmitters, if you don't one of those brands, you will have to install your rx to make it work.
Old 10-25-2006, 03:21 PM
duaneh1
HeliTB, I'll post my settings this evening.
Old 10-25-2006, 07:18 PM
HeliTB
HeliTB's Avatar
duaneh1...Thanks can't wait to see what have programmed.
Old 10-25-2006, 08:19 PM
duaneh1
Settings for Optic 6, Nowadays I only use Idle up 1, normal mode is to initialize the Gyro. I don't have my other idle ups set.
Normal
Swashplate % 63, 66, 40
REVO Mixing -> 0
Throttle Curve: 0, inh, 75, 87, 100
Pitch Curve: 35, Inh, 60, 74, 100
Idle up 1
CCPM Mixing -> 63, 66, 40
REVO Mixing -> R/U +45, L/U -32
Throttle Curve: 100, 100, 75, 100, 100
Pitch Curve: 0, Inh, 50, Inh, 100.
Old 10-26-2006, 07:38 AM
HeliTB
HeliTB's Avatar
Thanks duaneh1. These are my settings
Normal
Swashplate % 80, 80, 40
REVO Mixing -> -5% R/D asecending and +5% L/U descending (this is with my HH Gyro)
Throttle Curve: 0, 25, 50, 75, 100
Pitch Curve: 55, Inh, 60, inh, 100
REVO Mixing -> -20% R/D asecending and -20% L/U descending (this is with the stock Gyro)
Old 10-26-2006, 08:47 AM
duaneh1
HeliTB are you using the stock swash or aluminum? It seems I can't get as much throw as the stock swash without the swash binding
Old 10-26-2006, 08:49 AM
HeliTB
HeliTB's Avatar
Stock swashplate. I'm getting +12 degrees, no binding
Old 10-26-2006, 08:59 AM
duaneh1
My collective is about the same. But I was referring to cyclic, I have the aluminum swash and it binds sooner that the stock swash
Old 10-26-2006, 10:42 AM
HeliTB
HeliTB's Avatar
You know that's funny. I have an aluminum swash on my Shogun V2 and don't get the same travel as with the stock.
So it makes me wonder is the aluminum that much better then?
Old 10-26-2006, 12:24 PM
savage 40
Freebird, can you help a guy out setting up with the 6exhp? My cp is channel 19 and TX is 48 would this pose any problems? What settings you use ? Thanks a bunch! Lookin' forward to this!
Old 10-26-2006, 12:48 PM
HeliTB
HeliTB's Avatar
I don't mean to jump in but, the rx and the tx need to be on the same channel to test and use the radio. You need to get another tx cyrstal, as the crsytals for the stock rx are limited to about 5 frequencies.
Old 10-27-2006, 09:44 AM
savage 40
I realize they are differant channels. I was concerned one was high band and the other low band.
Old 10-27-2006, 01:54 PM
Mike Ledbetter
I think you should change the RX crystal, not the TX crystal. Just get a Futaba short Rx crystal to match your TX.
Old 10-30-2006, 09:44 AM
savage 40
thanks ! now for the Futaba settings..
Old 11-07-2006, 01:48 AM
Ken29
Do you have the settings for the futaba 7chp radio in regards to the blade cp?
If you do, would you mind posting them? Thanks
