some stunts blade 400
FL
AZ
RE: some stunts blade 400
I noticed you switched your servo's to Hi-tec as well. Did you have any problems? My blades are out of whack when I switched servos.
FL
yes i swiitched to hitecs they are good. what you need to do is first reverse your ELEV-R RUDD-R PITCH-R with hitecs GO IN YOUR RADIO SETTING IN DX6I TO REVERSE AND REVERSE THE ONES I HAVE LISTED. YOU MUST CENTER YOUR SERVOS AT MIDSTICK. AFTER THAT LEVEL YOUR SWASH PLATE. THEN PUT THE HEAD ON THE HELI GET YOUR PITCH GAUGE NOTE MAKE SURE YOU THROTTLE hold is on so heli dont spool up on you. with the battery plug up the battery to your heli. set your left stick to midstick get your pitch gauge on the blade the top of the OF THE GAUGE MUST BE LEVEL WITH THE FLYBAR do both of your blades. if they are out of wack ajust the linkage till its level i think your tracking is way way off maybe you did not center servo i hope this helps you get back with me. as far as servo go the eflite servos suck they can quit in flight stay with hitecsHS-65HB ABOUT 25.00 A POP WHAT YOU WANT IS EVERYTHING LEVEL AT MIDSTICK good luck i hope this helps you
NV
this must be why my newly aquired blade 400 is acting like its full of gremlins. It has all hitec servos and I did the new settings on my dx7 and it has a mind of its own.
AZ
I took the the heli and the servo's back to the LHS where I bought it. They were fantastic in helping get it squared away. I already figured out the reversing stuff, just had to weed out the other gremlins.
NV
Does it fly normal now? My swash is level and all servos are at 90. When I turn it on it stays at left cyclic. Pitch seems good but cyclic controls are whacked. Are you using a dx7?
AZ
Use your sub trim to make adjustments. Take it up for a little hover and adjust your sub trim. Mine were whacked enough where I needed to make some adjustments on the aileron arms.
