E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
She flies!!!!!!!
Old 08-08-2010, 07:23 AM
tandem4
Default She flies!!!!!!!
After a long lay off ...... since September last year when we moved from Angola toSouth Africaand then beginning of the year to Nigeria the Blade 400 is flying again!!!!!! It is rainy season here and inbetween tropical rains storms I mananged to get her up into the air a few minutes ago. A few short nerevous hops and then!!!!!!...... I managed a low level very unsteady hover for thirty seconds. Then the rain came again!!!!!!!
While in South Africa it was hectic and I had the mSR to play with, I never toueched the Blade. Then we moved to Nigeria and with our first home leave in May I brought the Blade here. I totally stripped her, servicing bearings with my new Greaser, reassembled and then set up....... and she flies!!!!!!! I need to balance the tail, do tracking, balance the main blades ...... but she flies!!!!!!!!
Old 08-08-2010, 09:47 AM
JPEE
Default RE: She flies!!!!!!!
ORIGINAL: tandem4
After a long lay off ...... since September last year when we moved from Angola to South Africa and then beginning of the year to Nigeria the Blade 400 is flying again!!!!!! It is rainy season here and inbetween tropical rains storms I mananged to get her up into the air a few minutes ago. A few short nerevous hops and then!!!!!!...... I managed a low level very unsteady hover for thirty seconds. Then the rain came again!!!!!!!
tandem4,
Well it looks like you have been through lately with all of that moving and bad weather. But at least your set and now can fly a bit. I am glad you like the "Greaser" too. Once a year on each bearing or a new bearing install and I have "never" had one fail, it is worth its weight in gold.
Good Luck JPEE
Old 08-08-2010, 10:19 AM
tandem4
Its coming down in buckets again....... like a solid sheet of water...... our monthly rainfall for August here 450mm plus..... last year it was amost 600mm!!!!!!
Old 08-08-2010, 11:58 AM
JPEE
OH CRAP! Tandem
450 mm = 17.71 inches
600 mm = 23.62 inches
Got rain?? JPEE
Old 08-08-2010, 12:41 PM
hottrk51
Can you imagine how much SNOW that would be?!!!! [X(]
Old 08-08-2010, 12:56 PM
tandem4
ORIGINAL: hottrk51
Only two seasons here....... dry season and rainy season..... always warm. daily between 30deg C and 40 deg C. If 30 deg c the locals wear jerseys!!!!!!
When we went to South Africa in May (southern hemisphere winter) Johannesburg temp hovered around ZZERO in the mornings. We almost died!!!!!!!!
Old 08-14-2010, 12:44 AM
tandem4
Still raining........ what worries most are the webs growing between my toes...... is that normal?????????
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
