cx problem
hey guys my cx seems to have a problem I think. My heli has full left rotation trim, and it still wants to go right. I can deal with it just it doesn't want to hover very well, becuse you have to constantly change the rotation. please respond.
Alex |
RE: cx problem
I would first check your motors by swaping the motor plugin on the controler and see if the problem is the same or changes the direction of rotation
Baggy |
RE: cx problem
Hey baggy how do I do that. I have only had this heli for about 4 days now.
Alex |
RE: cx problem
Alex your CX has a (4 in 1) that both motors are pluged into. This (4 in 1) controls the birds flight but more importanly the motors. As the bird is flown the motors get weaker and at some point need adjustments of the rudder trimbut when the rudder trim can no longer correct the rotation problem you will need to get back into your owners manuel and see how to adjust the mix trim pod on the (4 in 1) and if you run out of adjustment there you can doa motor test by simply reversing the plugs. It the bird spins in theopposet direction you have a warnout motor. Good luck and happy flying.
Baggy |
RE: cx problem
I adjusted the mix trim and that seemed to work. THANKS!!!:D
ALEX happy flying |
| All times are GMT -8. The time now is 10:07 AM. |
