blade cx2 issue
Hey fellow modelers Ijust purchased an Eflite Blade CX2. Charged the battery went to fly it and the darn tail would rotate to the right very fast once it lifted just off the ground. I read in the manual on the trim screw to attempt to fix this problem. Iadjusted the screw very slowly in both directions and yet it still spins toward the right as soon as the skids are no longer being held down. Iam new to helicopters and am not sure what to doto try and fix this problem other than sending it in to be repaired, any suggestions on what to do?
RE: blade cx2 issue
Did you try adjusting the trim slides on your tx as well?</p> |
RE: blade cx2 issue
Yes Itrimmed it all the way and still does not help the spin it is almost as if the one motor is putting out more power than the other causing the main blade to spin faster than the upper blade.</p> |
RE: blade cx2 issue
littleman,
Go to this thread down the page and read my post. http://www.rcuniverse.com/forum/m_10556453/tm.htm It pertains to a little different problem but they can be related. Because you have already tried to adjust your "POTS" on the 3 in 1 take a look my post. You understand that when you kept adjusting the pot to stop the heli from doing 360's you HAVE TO UNPLUG the battery and restart the 3-1 EACH TIME after an adjustment. So to be clear, you land and unplug the battery and adjust the 3-1. Then you re-conncent the battery and see how your adjustments work. Good Luck JPEE |
| All times are GMT -8. The time now is 10:37 AM. |
