RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   CX3 (https://www.rcuniverse.com/forum/e-flite-helicopters-447/10855176-cx3.html)
albramley 12-11-2011 09:22 PM
CX3
Have a roll issue with a CX3 i picked up last week, seems to want to flop over to the left on lift off and while in the air, hardly any right roll and seems to want to go forward, had the trim for roll all the way to the right and elevator trim all the way back, i adjusted the linkage on the right swash servo linkage almost as far as i could to pull the swash down but does not seem to make a whole lot of difference, new swash plate perhaps, Help!
Cheers
Al
Mack66 12-12-2011 01:50 PM
RE: CX3
Sounds like your swash plate separated. Did you crash before this started happening?
If that's not it, call tech support. They're very good about helping you. I don't know about having them call you back when you call from Canada, but it's worth a try. You can call and give them your number rather than waiting for your turn on eternal hold.
If your swashplate has separated you may be able to fix it by merely sqeezing it back together. If that fails, and if the swashplate is separated, it would indeed indicate replacement.
Mack
albramley 12-13-2011 04:24 AM
RE: CX3
Hey Mack, thanks for the reply, thats exactly what was wrong, THANKS! Have a micro heli cnc swash and a few other goodies on order for it now.
Cheers
Al
Mack66 12-13-2011 05:32 AM
RE: CX3
Hoo-RAY! :)
Glad I could help.
Mack
