RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   What lipo (https://www.rcuniverse.com/forum/e-flite-helicopters-447/4606262-what-lipo.html)
wrh117 08-10-2006 12:00 PM
What lipo
I have a Blade cp, What lipo can or should i use?
hover_lover 08-10-2006 02:05 PM
RE: What lipo
Depends on what type of flying you do.
In my opinion...
A beginner that is hovering and doing mild FF will enjoy the long flight times provided by a larger battery such as a 1320mah 3S (ThunderPower makes great batteries).
For 3Ding go smaller like 900mah 3S. Shorter flight times, but much less weight so you can crank it around.
HTH
Gonwee 08-10-2006 06:46 PM
RE: What lipo
From what i've read. The stability is the only thing a larger lipo gives you. They take more power to hover because of the weight. And people with 700-800mAh lipos get about the same as ones with the higher mAh lipos.(but i could be wrong, i haven't really used a lipo on my blade)
wrh117 08-10-2006 06:56 PM
RE: What lipo
I have no plans on 3d just want to learn scale flying and longer run time is better right? Anyone run a 1300? I just want to be sure it can handle the extra volts
Gonwee 08-10-2006 07:00 PM
RE: What lipo
ORIGINAL: wrh117
It can handle 3 cell lipos. But you need to get a 9 tooth pinion motor to keep the head speed down.
A higher capcity pack will make it as stable as the stock nimh, but with more power. The smaller ones make it not as stable, but more manuverable.
ct420 08-10-2006 07:02 PM
RE: What lipo
I have a Thunder Power 3S 1320mah lipo with 8t pinion, and can hover for about 25-30 mins. You ain't gonna do that with an 800-900 :)
Gonwee 08-10-2006 07:03 PM
RE: What lipo
ORIGINAL: ct420
I read somewhere someone got 24 minutes with a 710.
But for just hovering and some forward flight 1300 or so is fine.
wrh117 08-10-2006 07:13 PM
RE: What lipo
Sounds great......... who am I kidding I'll probably crash in less then 2 minutes
