RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   bcp flybar weights (https://www.rcuniverse.com/forum/e-flite-helicopters-447/4759663-bcp-flybar-weights.html)
bayfire300 09-17-2006 04:40 PM
bcp flybar weights
hey guys i am getting better a very lil at a time lol ....but today i bent the main rotor shaft......oh well .....but i swore i read somewhere on here that adding flybar weights hep tame the cp down a lil ...is that true?.
thanks
otto
scottsr 09-17-2006 05:39 PM
RE: bcp flybar weights
Yes it is true . The same as heavier paddles they do the same job . When your flying 3D you want your flybar light and your paddles light for snappy moves and the opposite for beginners . :)
Psikelly 09-17-2006 05:41 PM
Yup. Add a weight on each side on the outside. The added weight should decrease your headspeed a bit and also slow down the cyclic response which tames it down. I havent done this but seen guys talking about taming them this way. When you think about it you can visualize how it would work.
Heli_Harry 09-17-2006 05:54 PM
I have a Blade CP Pro
I added extra weights (1 wheel collar each side) to my flybar.
Put on Plasti Blades (more weight)
Turned up the pitch on the blades (1 turn on the links), I may go anther turn
It calmed the CP Pro Down and made it easier to fly
bayfire300 09-17-2006 06:27 PM
great thanks guys ......i'll order some collars .......i already have the plastic blades and suffered a boom strike .wasnt to bad just a lil crack..........i solved that problem w/ a carbon arrow and some epoxy i had layin around.
thanks again
otto
Heli_Harry 09-17-2006 06:36 PM
As far as your bent main shaft goes...
Pull it out and roll it over a flat surface (plate glass, ground metal surface, etc)
Find the bends and with a hammer tap them out.
I put a block of wood under it and keep tapping at it until it it straight again.
Works like a charm
bayfire300 09-17-2006 07:04 PM
awsome trick ad5tb.....i did it and that took all but 2 minutes ........works great........i knew the shaft was bent for a while now just wanted to fly it more b4 repalcing it ........glad you told me that trick ..now it's a lot easier to get off the ground and lil easier to control .....shoulda done that sooner
thanks again
otto
Heli_Harry 09-17-2006 07:52 PM
I have two main shafts on in the Heli and one that is straighted out and ready to go.
When I bend one I swap it out and then straighten out the bent one for the next time
My son picked up a used Blade CP for $100.00 and It had the shaft between the two blade grips that was bent I straightened that one out too.
I keep the broken pieces around and fix them when possible.
keep reading the forums there are a lot of good tips in here.
Biker-74 09-18-2006 05:59 AM
ORIGINAL: ad5tb
So do I. Quite often. I don't always find time to straighten the bent one before I find myself with two shafts to work upon. :D
Then again, I guess it's more efficient to straighten the two at the same time. :) (You know, tools already brought out to the workbench, etc.)
ORIGINAL: ad5tb
Wish I (we?) could do the same for the wooden blades.
Biker-74
Heli_Harry 09-18-2006 01:34 PM
Oh but those Plasti blades are so cool when they hit stuff
Had a boom strike yesterday
Blades Dented
Boom Shattered
Good thing I kept a spare boom on hand.
I'm almost convinced there is a CBer in the neighborhood as I and my son both get glitches
I had the freq counter running and the wide band receiver to try to find it (source of interference)
Biker-74 09-18-2006 03:59 PM
ORIGINAL: ad5tb
Yeah. I got those plasti-blades. Just mounted them. First flight ended up in a dead-chicken-dance after less than two minutes.
One of the plasti-blades is dinged out beyond repair. Will go back to them flat-bottom woodies after all.
Biker-74
supac 09-18-2006 05:12 PM
My CP Pro is a juggernaught now with the following:
-Flat Bottoms Plastiblades
-G90 Gyro
-E-power 11.1V 3s 1300mah lipo
-Superskids
-flywbar weights
drphoto 09-18-2006 05:40 PM
ad5b
try different antenna routing. the heli guru at the LHS told me the wire wrapped around the skid is not a good idea, despite what Horizon claims. I'm running mine down a long plastic tube. Also put a ferrite ring on the main motor pigtail.
seems better now (I was plagued by glitches) but it still does that weird little 'jumping' thing. I dunno if that's radio related or the swash sticking or some other mechanical problem.
I'm eventually going to get a high end PCM radio.
Heli_Harry 09-18-2006 05:47 PM
drphoto
I was thinking about running the antenna down a tube along the tail boom
or going with one of those mini antenna's
Then again this may be reason to buy one of those Spektrum radios ;)
