Broken TX antenna
I have a broken spectrum 2.6ghz antenna on the TX for my CX2. I ordered a new one, but it will not be here till some time in January or February. Does anyone know where I can get one sooner or have a way that I could fix something so I can fly. I did find a antenna wire like the one from the TX it is not as thick but the plug works. It plugs on a small board in the TX. I routed it up into the broken antenna and fixed it all with electrical tape. Is there some type of difference in a 2.4 ghz antenna verses a wireless antenna from a old laptop( that is were I got the wire from). I do notice that my servos (left and right control) will pitch hard left and hang making a whining noise. I have to disconnect the battery and turn off the transmitter to fix this issue. I feel this is a signal issue. Any help would be greatful.
RE: Broken TX antenna
How is the stock antenna broken?
The swivel link on my DX-6 broke.. I just goo'ed in position, straght up. |
It broke at the swivel point then the wire got pulled loose. It pulled (the wire)off the gromet that connects it to the little board in the transmitter. I am going to try a little reverse engineering at home and see what I can come up with as a temp. fix and the wait continues.
I took the stock antenna apart, replaced the wire with a simalar wire. Resoldered it back in place on both ends. I can now go about 400+ feet out and no problem. As with the cx2 the servo was shorting(that is what the hobby guy told me). They are sending me a new one ASAP. Other than that the CX@ is awsome and fun to fly.
1 Attachment(s)
I figured it would only be a matter of time before I broke off the little 3dB antenna so I have already modded it to a replaceable style. Now I can also change it out to any number of High-Gain Antennas that we stock. 3dB, 5dB, 7dB or 9dB. Range should not be a problem. 3dB and 7dB pics attached.
Rich |
High-Gain: WHat antennas do you stock? Do you have any swivel antennal for Futaba 9C's?
Cool do those High-Gain Antennas work with stock Cp pro TX
