Installing an AR6100 in a CPP
I got a DX7 for my birthday (thanks to my wife), and I'm using it on my CX2 (not very exciting). I ordered an AR6100 for my CPP and would like to know if anyone knows of a link to an install FAQ or anything else to shed light on any things to watch out for. I believe the 3 in 1 uses an LD1117A BEC which is 5 volts..so that should be OK. Do the S75 servos work directly ? ...that kind of stuff...I've found some info but mostly it is post install problems and setup...thanks for the help..
RE: Installing an AR6100 in a CPP
The s75 servos work with the AR6100, no problems for me, its pretty much straight-forward on installing it.
Yep just make sure to watch the servo reverses are set right. Took me a bit of tweaking to figure out the sweet spot.
Also check out helifreak website for DX7 setup |
| All times are GMT -8. The time now is 09:28 AM. |
