RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   CX2 Problems (https://www.rcuniverse.com/forum/e-flite-helicopters-447/6750237-cx2-problems.html)
docnee 12-12-2007 11:08 PM
CX2 Problems
Ok. I had a little crash with my cx2. No visible damage. Since then, the upper rotor rotates at an obvious slower rate that the the. lower. Initially after the incident, the motor was making a winding noise, which has since stopped. However, the upper rotors will not produce enough RPM's to offset the lower blades; therefore, the heli just sit and spin. HelP!
eat2muchrice 12-12-2007 11:55 PM
RE: CX2 Problems
sounds like your inner shaft and gear is off.
check out this link to help you fix it.
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
