RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   blade cx2 problem.....help (https://www.rcuniverse.com/forum/e-flite-helicopters-447/6835154-blade-cx2-problem-help.html)
Julian Maza 01-01-2008 02:33 AM
1 Attachment(s)
I just crashed my blade cx2 and whenever i throttle up both of the blades spin in the same direction. The shaft moves slightly up and down, whenever i pull it up the blades spin properly but when i let go of it the blades spin in the same direction.I think the problem is that when the shaft drops the gears get connected somehow but i don't know what to fix it with or what new part i need.
This is my first heli and i don't know anything about them
Any help would be much appreciated. thanks, Julian
eat2muchrice 01-01-2008 02:42 AM
RE: blade cx2 problem.....help
1 Attachment(s)
Your shafts are bent and the gears are falling out of place. You need to check the upper head and the lower locking collar under the swashplate.
loosen the screw on the locking collar, slide it all the way back down and tighten. Look at the picture below
These two links will help you out.
Soloboss’s Guide
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
Dacaur’s Guide
http://www.dacaur.com/bladecxhelp.html
Julian Maza 01-01-2008 03:09 AM
I did what you said and it worked. thanks a bunch.
desertfalcon 01-07-2008 03:37 AM
hi,CAn someone help me with my Blade cx2, my 4 in 1 receiver has been burn out . Does somebody know where do you buy it i have been trying now for sometime.
John FRANCOIS
evdreamer 01-07-2008 04:27 PM
horrizonhobby.com, helihobby.com, helidirect.com, I think UShobbysupply.com has them too.
desertfalcon 01-07-2008 06:22 PM
