Xtreme 180 problems
I may have pushed the pinion gear down too far, as it was a little high. It doesn't feel like it's making too much friction. Have a hard time moving it back up. Any thoughts?
RE: Xtreme 180 problems
There is a tool called a pinion puller that would do the trick.
Maybe a pair of ball link pliers would work as well. |
[:@] I did that too when I first got mine.
I used a small screwdriver to wedge it back up slightly. |
Which one is the pinion gear?
R/B |
ORIGINAL: rikybob Which one is the pinion gear? R/B |
I've seen it. Didn't know you could move it. I did find out one thing though. My "right" motor is raising hell. Squeeks pretty bad. I said to my self, "self, it needs some oil to stave off replacement". So's I get a toothpick and some 3 in 2 and put a drop on that same pinion gear and VOILA! I rekon its time for 180's.
Rikybob |
| All times are GMT -8. The time now is 06:07 PM. |
