What is the default power setting on the Blade 400 3D
I just got a Blade 400 and notice that the factory power setting on the the transmitter is the A option for European countries. Is this correct or should it be B for U.S. I'm in the U.S., so that's why I'm asking. Thanks in advance.:D
RE: What is the default power setting on the Blade 400 3D
B for the US.
If I remember correctly I did have to change that but it could of been after I lost all of my settings.[:o] Either way if your in the US you'd want to use the "B" setting. |
Power setting between euro and us ?
Im an electrician, and the only differences between US and Euro is our mains ( wall ) supply US is 110 volts and Euro is 240 volts so i guess that its referring to and mains adaptors or input for adaptors |
This actually affects the transmitter power. Europe has lower limits on the amount of power the transmitter can put out than the US.
But should the power setting in my transmitter should be option B for the U.S.?
| All times are GMT -8. The time now is 01:10 PM. |
