hardware question
what screws are used for the lower rotor head on the cx2? there are 4 holes. are they the silver screws or the black screws? also, what screws are used for teh shaft retaining collars? i took all of that off to check if my shafts were bent and now i dont remember which goes where. and the exploded parts view doesnt specify which screws are used where... thanks
RE: hardware question
The lower rotor head screws are black. The retaining collars are thicker silver screws.
thank you. also, the lower retaining collar has two screw holes but the exploded parts view only shows 1 screw used in it. and if the third silver screw doesnt go there, then im not sure where it goes. lol. i have 3. 1 goes in the lower "gear side" area collar, and the other one goes in the other collar up near the swashplate. so where is there another large silver screw used? i know there are two shorter ones used on the flybar/upper rotor head mount, and 4 skinny long ones for all for blades... but im sure you know the ones i mean, the ones that go with the collars. see another one like it anywhere around either shaft? haha. thanks.
Yea two screws go into the bottom retaining collar.
weird, i guess the parts view is wrong. thank you very much! =)
Your welcome.
| All times are GMT -8. The time now is 02:13 PM. |
