How do I replace tail motor?
I can't figure out how to replace the tail motor of the CP Pro without breaking something off...
Any help would be appreciated! |
RE: How do I replace tail motor?
Just unsolder the two wires. Take the two silver screws out that are holding the motor to the mount. Then just pull the motor out. You will probably need to pull with a little bit of force since the pinion is a tad bigger than the hole. Hope that helps.
Nick |
ah that makes sense, thank you very much
| All times are GMT -8. The time now is 01:42 AM. |
