Replacement CPP Rx?
Is there any reason I can't replace the EFLH1036 72MHz receiver in the CP Pro with an AR6100 or equivalent receiver?
RE: Replacement CPP Rx?
SCV,
Sure, I did mine a long time ago...and a major improvment, I might add!;) This is assuming, of course, that you have a DSM2 Spektrum radio to go along with the AR6100....[X(] Hope this helps.... Glenn |
ORIGINAL: rotarydoc SCV, Sure, I did mine a long time ago...and a major improvment, I might add!;) This is assuming, of course, that you have a DSM2 Spektrum radio to go along with the AR6100....[X(] Hope this helps.... Glenn Way better than I deserve to be flying with... :) Thanks! |
It Werks!
| All times are GMT -8. The time now is 09:23 AM. |
