Repair shops
Anybody know of a blade cp repair shop.Big tronix problems tired of messing with it.Dan
RE: Repair shops
Dan what kind of tronics problems? maybe i can help
Thanks Micromike |
RE: Repair shops
Well its a blade cp pro,up graded with a 2n1 ecs.The 2n1 turns red but the rest of the helo is dead,the only time things move is when the xmitter switch is cycled on and off and thats just a glichDan
RE: Repair shops
Check for 5 volts on the black and red pins of the connector going to your reciever from your 2 in 1. If you have a brushless setup make sure you disconnect the red wire going to your reciever from the ESC. There is a BEC in the ESC so you do not want this working against the 2 in 1 BEC.
look at page 33 of 40 http://www.e-fliterc.com/ProdInfo/Fi...350-Manual.pdf Thanks MicroMike www.radiocontrolrepair.com |
RE: Repair shops
Thanks I"ll try it.Dan
RE: Repair shops
Sorry to take so long got busy.I do have 5 volts to the reciever,so my guess is the reciever is bad or a crystal.Dan
