RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   CX2 lower blade tracking problems (https://www.rcuniverse.com/forum/e-flite-helicopters-447/9425964-cx2-lower-blade-tracking-problems.html)
flyinbgl 01-18-2010 09:28 AM
Does anyone know of a good method for correcting tracking problems for the lower blades on a CX2? I've had problems even when the blades are perfectly balanced. Thanks for your help.
Jester966 01-18-2010 09:55 AM
RE: CX2 lower blade tracking problems
Boiling the blades can help. If not, then replace them with a set that are better matched for both weight and pitch.
flyinbgl 01-18-2010 11:04 AM
Thanks for the info. I can check weight but how do you match pitch? Also, what does boiling the blades do?
DreamHeliProducts 01-18-2010 11:24 AM
Boiling the blades helps to take stress & warp out of the blades so they'll relax & hopefully match each other a little closer. To match pitch, lay them flat on a table & compare.
flyinbgl 01-18-2010 11:33 AM
Thanks, much appreciated!
DreamHeliProducts 01-18-2010 12:01 PM
But, don't forget too - mistracking is ok if there are no other flight issues. If it's not wobbling, toilet bowling, or circling, then having the blades off track a bit is just fine.
