Convert from Blade CP Pro to CP Pro 2
Anyone know what I need to convert from analog transmitter Blade CP Pro to digital spectrum DX7 transmitter on my old Blade CP Pro using same as CP Pro 2 with AR6100 receiver.
I want to see whether it worth for this conversion. I already has DX7. |
RE: Convert from Blade CP Pro to CP Pro 2
I am looking to do the same converision but with a HobbyKing HK-7X 2.4Ghz ($59.00). Looking for any info.
Hey guys,
First of all, it's a huge improvement, going from the standard 72 Mhz analog radio to the 2.4 Ghz units... tea, if you have the DX7, and the AR6100, you are all set, just swap the stock 72 Mhz receiver with the new AR6100, and then of course you will have to set everything up in the radio, which can get involved, no doubt about it. But hardware speaking, you are all set, just swap the RX, and put the connectors in the appropriate pins/terminals on the AR6100. Lanny, Same story, I'm assuming the radio you mentinoned comes with the reciever. If not, you'll need a matching receiver, of course. The hardware swap is easy guys, but the setup of the radio is another story...getting the pitch, throttle curves all setup...you basically need to start from scratch all over, with getting the servos at 90 degrees at mid stick, using sub trims if necessary, etc. The payoff is well worth it though, the adjustabitlity of the computer radios is soo nice, and you'll be operating glitch free, and can dump the stupid wire antenna to boot! Have fun...let me know if you guys need any more info... Glenn |
Thanks RotaryDoc for the fast reply. Yes the radio comes with the receiver and for $59 + shipping its a great price for a starter system. Here are the radio specs.
Features: LED display, Show model type and battery voltage on normal status. 5 models parameters store supported Support HELI(helicopter) mode and AERO mode. Following mode is supported in each mode. Heli mode: HP1 : Normal helicopter with 1 servo HP2: Swash helicopter with 2 servos HP3: CCPM 120 swash helicopter with 3 servos AERO mode: AP: Normal aero plane VP : V-tail plane DP: Del ta wing plane 7 channels standard servo signal output Support 5 points throttle(THR) curve on NORMAL mode and IDLE mode. Support 5 points pitch(PIT) curve on NORMAL mode, IDLE mode and HOLD mode. Set reverse (REV), sub trim (SUB) and travel by LED and button. Dual rate (DR) control supported Throttlehold supported Gyro sensitivity adjust supported Return to battery voltage display after no operation till 30 seconds. Beep when battery voltage low than 8.6V (Once per second). Included; 1 x 2.4Ghz transmitter 1 x 2.4Ghz Receiver 1 x Bind Plug 1x Manual |
lanny,
Looks like a great deal....can't go wrong as long as the quality is up to par, for sure!;) Glenn |
The 3-in-1 units and receiver seem to looks like one unit. Can it be separated? Does anyone has done this and has some photos with instructions that can show me how. What about the external Gyro unit? Can I still connect the gyro control from channel 5 on old receiver to new AR6100 receiver? I want to be able to adjust the Gyro gain on the DX7 transmitter just like to old one. Also can you list out all the setting on the DX7 transmitter to for beginners users with expos and dual rates setting? Thanks in advance.
