RCU Forums
-   E-Flite Helicopters (https://www.rcuniverse.com/forum/e-flite-helicopters-447/)
-   -   Blade MSR battery options? (https://www.rcuniverse.com/forum/e-flite-helicopters-447/9613551-blade-msr-battery-options.html)
JuiceGoose 03-26-2010 09:43 AM
Guys I see that e-flite offers the 150Mah battery for the MSR. In your experience is it worth the extra cost compared to the standard 120's that come with the chopper.
Also What is a good alternative to the e-flite batteries? something I could still use the stock 4 place charger for?
rabbottfl 03-26-2010 12:48 PM
RE: Blade MSR battery options?
I have the e-flite 150mAh batteries, and I definitely like them better, I get about two or so more minutes of flight time as compared with the standard batteries
I have not tried other brands on the mSR for two reasons. 1. I have not found another battery with the same connector that fits in the provided Celectra charger, and 2. The e-flite 150 battery comes with a a 'spacer sleeve' on it that adjusts the balance correctly for the extra weight of the battery.
I fly to soft-shutdown every time i fly, and the 150s seem to be holding up well to that. I would estimate I have about 60 cycles on two standard and two 150s now. As I replace them, I'll go with only 150s.
This mSR is fantastic. I get the most flight time and the least repair time from my mSR.<br type="_moz" />
patryn 03-26-2010 01:07 PM
I have 2 120's and 2 150's. The 150's definately allow a good bit more flight time and make it easier to bring the heli down when it runs out of juice.
kf6bbl 03-26-2010 04:48 PM
Only thing I can add beyond what was already mentioned, is that the 150  does change the flight characteristics slightly. In slow flight or hover, no difference, but once you get into doing fast turns, that little extra weight seems to cause it to over rotate sometimes, and it also carries through the turn a little further. I'm sure all of this is just me being accustomed to the standard battery, and I can learn to fly the 150 differently. Switching back and forth from the 120s to the 150s messes with you a little though.
That said, I get 6 min form the 120s, and 9 min from the 150.
Sasquatchin 03-29-2010 07:46 AM
I have 4 120's and a 150, I like the 150 better, and will be getting more
Stone624 04-09-2010 02:01 PM
<font color="#000000" size="4">My fav is the </font><font color="#0456ff" face="Verdana,Arial,Helvetica,Univers,Zurich BT,sans-serif" size="-1"><font color="#5c5c5c" face="Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif" size="-1"><font color="#000000" size="4">lightning power 130mAh, I get about 5-6 mins but I find my msr has a bit more power then when using a e-flite oem. I have also tried the zippy flight max 138mAh from hobbyking for like 2 bucks each, bought 4 of them and can say power output wise they feel the same as the oem e-flite's but flight time is about a min to min and a half shorter in my experience.</font>
</font></font>
SpikerNY 04-12-2010 04:09 PM
Hi,
I recently purchased a Tenergy 160 mAh 15C battery that fits the mSR perfectly. I am getting about 12 minutes total flight time and only cost 6.99 where the E-Flite 150 mAh was 12.99. It is longer than the stock battery which had me worried, but it alos has a black collar and I push it all the way in whichI thought would make the mSR front heavy, but it flew fine without any back trim or anything that i normally don't do with the stock battery. Of course you can always pull it back out a bit if needed to adjust C of G but I didn't find it necessary. One thing is when you first install and then take off the mSR does have more power so be ready for it if you go with this battery. Anyway, I liked it so much i went back the same day and bought another and it also fits the Celectra charger just fine. Ibought mine at Performance Hobbies which is also (lucky for me)my LHS. These will most likely be the only batteries I buy for the mSR due to cost, power and long flight times. I am sure you can all find them on line somewhere. The brand Tenergy has an N that looks like a lightning bolt and is in red on the battery. Doesn't have the red dot on the back (the plain side) but just remember the label side is opposite of the dot when plugging into the heli.
SpikerNY
Blade mSR - Blade SR (soon to be Blade 400 too, and Raptor 50)
lot 04-16-2010 06:06 PM
ORIGINAL: SpikerNY
+1
I have three of them and so far they are great
http://img219.imageshack.us/img219/8554/tenergy.jpg<br type="_moz" />
JsK 04-19-2010 03:21 AM
[link=http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10980]TURNIGY 160Mah 1s 30c[/link]
lot 04-19-2010 03:34 AM
No offence but I'll take the tenergy over the tunigy anyday
icebox 04-20-2010 02:54 PM
Anyone have any experience with the above "Turnigy 160 mah" batteries? Having trouble finding the Tenergy 160 mah from Performance Hobbies. Thanks guys.
NobodyFamous 04-20-2010 07:59 PM
I bought a total of 7 of the <span style="font-family: Verdana, Arial; font-size: 13px; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ">Tenergy 130 mAh from my LHS, and returned 5 of them.  1 had a bad connector, and 4 would not take a charge.</span>
