Electric Aerobatic & Sport Planes Discuss rc electric aerobatics and rc sport flyers here.
NitroPlanes - MQ-9 REAPER
Old 10-25-2010, 05:34 PM
  #101
WordyBirdy
Default RE: NitroPlanes - MQ-9 REAPER
I think you are underestimating the bonding power of epoxy. Although it might seem the epoxy is being "wiped clean" as you slide the 1/4" tube through, enough is left to bond.And bond it will.
Old 10-26-2010, 08:41 PM
  #102
papajeff
papajeff's Avatar
Wordy is correct about the power of epoxy. I do suggest to roughen up any surface that you want to epoxy
because it does add to the strength of the finished joint.
I am confident that you will be pleased with your Spektrum Tx and Rx for the Reaper or any other plane
that you may have or want. In addition, with respect to electronics, I have always had great success with
CastleESC's and CCBEC, E-flite Power Series, AXI, AMMO,Hacker and Monster Powerbrushless motors,
JR, Spektrum, Hitec servos and Enerland, Thunder Power, FMA Li-Po packs.
Old 10-26-2010, 09:45 PM
  #103
WordyBirdy
Thanks for info. Ihave been searching literally every distributor for an electronic/motor package and have decided to go witha .32 42-50-800 rim fire motor for the reaper.I am leaning towards a flight power EON 3350mah 30 c 11.1 v battery, and a 60 amp esc silver series. Ihave until tomorrow morning to make a final decision, or Ilose the contract... what a wonderful job...gettingpayed to build andfly these planesfor a client.
Old 10-26-2010, 10:17 PM
  #104
Desertlakesflying
My Feedback: (28)
Annnndddddd...Of course they are out of stock like everything else always is.
Old 10-27-2010, 10:03 AM
  #105
crustychief
I have 9 flights on my Reaper. It is not an easy star, but I find it manageable. I have never felt the need to use flaps so they have not been deployed for landing ( on the second flight they were deployed to check for adverse roll, but not used for landing). I am using an AXI 2826/12 motor with a 40A speed control, 2 4S 2100 batteries in parallel. I use a 3 blade  12X6 prop in a tru-turn spinner. The thing blasts off the ground and I usually throttle back to 50% on recent flights. My speed control is back by the motor. I ran a 24" extension with deans connector at both ends and have had no problems. after a 9 minute flight my batteries are nice and cool as is the speed control and motor. On the last flight I let my 15 year old son fly it and he landed like he lands his Extra 300. the rudder got bent over but it is an easy fix. It slows down fast when you cut the throttle. Don't be afraid to fly the plane, it really is fun to fly and everyone loves it! it just requires adaptation to its unique flying qualities. Watch the crosswind landings.
Old 10-27-2010, 08:59 PM
  #106
WordyBirdy
I looked for the specson the AXI 28- motor, but gave up. Who makes that model?Iordered the Rimfire .36 42-50-800; the 60a platinumesc; and got a flight-power EON X 30c 3s 11.1 5000 mah battery. Plus all the odds and ends. That is for the reaper,which I haven't begun to construct...I am working on the predator first. I wont bore anyone w/ the package I intend to putinto that experiment.
I do want to point out thatduring the past week and a half,I have seen a many number of personal suggestions (including pics, illustrations,video's etc.) on how to best build the reaper and predator. This forum and various others have made my two projects more discernable. I take the advise of some, and toss some aside as inferior. Onething I have noticed more than any other is everyone tends to start off planning on minimal weight, but astime goes by, (some pictures later) I seewhere the modeler is crammingeverything butthe kitchen sink in the bird. Things getpacked sotight, some are strappingbatteriesinside (and at the top) of the front canopy - making it top-heavy...to either side of the fuslage insteadof dead center...this has got to be some of the reason why these planes aretipping in left or right stalls. And when that happens, the weight of the batteries (centrifical force out of control) prevent a pusher thruster to regain equalibrium. If the batteries are centered directly down the middle of the fuslage, your less likely to tip.
Furthermore, I've seen many who are cutting out the bottoms ofthe fuslage to gain acceess to the centerfuse, but I am seriously considering cutting out the battery and servo trays to gainentrance into thegut of the model, then scabbing (epoxy) everything back in. While I am at it, I think I'll drop the battery tray down a half inch or so, and back towardsthe CG. an inch. That certainly is a better concept than hot glueinghalf a pound of batteries against the top of the dome. Reminds me of that cheap car Yugo, that was rolling over on exit ramps killing folks, due to it being "top heavy".
I'll then re-examine the weight distro andget the CG right at that point.
Old 10-28-2010, 09:45 AM
  #107
crustychief
ORIGINAL: WordyBirdy
I looked for the specson the AXI 28- motor, but gave up. Who makes that model? .....
AXI makes it and is distributed through varoius outlets. http://www.hobby-lobby.com/brushless_axi2826.htm
Specification
No. of cells 10 - 18
3 - 5 Li-Poly
RPM/V 760 RMP/V
Max. efficiency 84%
Max. efficiency current 15 - 25 A (>78%)
No load current / 10 V 1,3 A
Current capacity 37 A/60 s
Internal Resistance 62 mohm
Dimensions (diameter. x lenght) 35x54 mm
Shaft diameter 5 mm
Weight with cables 181 g
Old 10-28-2010, 10:23 AM
  #108
ptmyers
Only issue with Hobby Lobby is that it is out of stock. I have had it on order there since 2 Sept. still waiting.
PT
Old 10-28-2010, 05:29 PM
  #109
rjmanzuk
Here's an alternative source, if still interested (they also have a 2826-10, if you prefer that over the -12):
http://www.atlantahobby.com/Store/pc...2-262p5231.htm
Old 10-28-2010, 05:38 PM
  #110
crustychief
I guess the e-flite 32 is a pretty close competitor.
Old 10-28-2010, 09:54 PM
  #111
papajeff
papajeff's Avatar
These are all good motors! Like the Chief, I plan to use the Power 32 as I have one already and it's
size fits perfectly under the rear bulkhead in order to allow mounting. I also tried the Power 46, but
it was too big to fit in that area. I really did not want to get involved in a mod of the "firewall"
especially a pusher.
ID:	1524665   Click image for larger version
Old 10-29-2010, 03:36 PM
  #112
kentek
PaPajef,
I see you are online.
I'm in final stage of getting ailerons-flaps hooked up to servos. The step I'm having issues with is which hole to put the swing arm (connection between servo arm and horn on flap).
Also, from an eariler post you show the flap horn set very close to hinge edge. In order to do that did you have to cut the mini rod connectors? If I screw then enough to adjust properly the rods press all the way to end of travel and restrict movement of servo parts.
And, lastly, (I'm winging it here) I installed the servos with the horn straight up or at about 50% of its potential travel. I'm trusting the controller will allow me to retrict movement because there is not enough room to do a full action as it will crush the cover.
Details, details, details...
ken wood
Old 11-05-2010, 09:46 AM
  #113
papajeff
papajeff's Avatar
Ken,
My linkage was the correct size and I just adjusted the final length by twisting the clevis on the control
rod threaded ends. The servo should be centered first with a servo adjuster and then attach the servo
arm in the proper position, as you stated at 50% of travel. In addition, I did have to extend the slot in the
servo cover to allow the servo arm to travel it's full arc.
Old 11-05-2010, 09:02 PM
  #114
WordyBirdy
Papa Jeff,
Again, thanks for the info that you generously post...your instructions and hands-on advise is thankfully, "world-wide-web".
Old 11-06-2010, 07:45 AM
  #115
dmenace65
here we go !! I just got my MQ-9 REAPER plane and this is my first rc ever. i have no idea what i am doing.
Old 11-06-2010, 07:56 AM
  #116
dmenace65
mine came with the rods rusting. other than that is awesome, some fiver still sticking up from inside the cam area.
Old 11-06-2010, 01:12 PM
  #117
kentek
I lopped off 100 grams of wieght by replacing metal rod for wings with a carbon fiber rod that I got for pretty cheap from a kite building store. The URL is on my office PC and I can't remember it.
I've done an unscientific test to see if it bends any more than the steel rod. I 'd say they are about the same.
On the antena tube I have a question: I bought some antena wire but don't know quite how to use it. As there are 2 wires on receiver do I add wire to both leads and string them both through the wite tube? Or?
Thanks in advance...
Old 11-06-2010, 01:13 PM
  #118
kentek
First for me too! More credit care than sense...
Old 11-08-2010, 04:18 PM
  #119
kentek
Moving ahead at snails pace I have finally installed my Robart Strut as replacement for the Reaper kit provides nose gear. It looks much more realistic and I don't have the adhesive issues that another builder has had.
Cost me $51 delivered so not too bad.
If any one wishes to do the same here is what I learned on installion;
Reaper instructions give no clue as to what the length of the nose gear should be. I proped up fuse to what I thought looked good based upon pictures of real Reaper on runway. I chose 6.5".
I figured in the kit supplied collar and cut the Robart Strut to 6-1/4". I would not use that length if I do over as it is not quite long enough to house the Strut insert. So, make it 6-1/2".
You have to install insert and then drill 2 #43 holes for set screws.
I am only using one set screw and it seems pretty strong. I may add another on oposite side of strut tube.
The Strut insert is a little large so I would recommend filing it down a bit so you don't have to work so hard to insert.
The Robart Strut wheel axle is a bit larger than the kit wheel allows. i drilled out and am not happy with result. I will buy a bit larger wheel that will allow this axle to fit.
Here a photos of how it looks...
Old 11-08-2010, 06:13 PM
  #120
dmenace65
Can you please post the web address or the info where you get this from? thanks
It looks awesome.
I am going to start buliding mine as soon as i get the carbon rod, Not till then.
Old 11-08-2010, 06:40 PM
  #121
kentek
http://www.robart.com/gear-finder
Robart sells to just about every RC dealer there is. I guess just do a search at your favorite: Robert Strut it is the 3/8' model. Exact info is in my office; it was
$51 include ship. I'll re email you in AM
Also, Carbon fiber rod: KiteBuilder.com I bought 1 1/4 X 48" for $6 plus $9 ship. I had them cut it down to 2 X 24" so it was easier to ship.
Also2, with the extra 24" pieceI replaced the 2 aluminum pieces for the Vtail attachment. I still have some left over. Save for next project.
kaw
Old 11-08-2010, 08:53 PM
  #122
dmenace65
Thanks for the info. I'll see whats the rods looks like when I get it then I'll see if I get a second Reaper. The next one will be fully loaded with FVP and cameras.
Old 11-08-2010, 09:16 PM
  #123
dmenace65
is this the same one you got?
http://www3.towerhobbies.com/cgi-bin...?&I=LXES74&P=0
thats the only one i found that looks like yours.
Old 11-11-2010, 12:02 PM
  #124
kentek
This just in:
I have installed just one of the four servo kit provided linkages to one of the ailerons.  If you follow the plans provided you are supposed to use the 2mm screws and drill through the aileron using the provided part to secure the horn to aileron. Well, when it is done this way it totally destroys the look of the  wings from the top view. The chunk white plastic just looks bad.
Does anyone have a better way of installing the horn to the aileron?
Old 11-11-2010, 12:12 PM
  #125
dmenace65
pics please! and what servos you going to use for that?
