Morris Dragonfly
Morris Dragonfly
Hi
how much does your plane weight? which battery? and which charger do you use?
I´ve flown a sp400 2:1 8x6 plane, AUW 800g, almost loopable from level flight. good power on 8xKAN950 cells 6-7min flights easy.
sounds like you got a heavy plane or wrong battery/charger
Morris Dragonfly
30oz... I think that is the upper limit, but it should still fly.
make sure to charge the battery just before flying.
1000mah, 500AR sized? HE1100 is good, KAN950 even better, there are some ~1000mah closes out there that is´t that good, maybe you got a bad battery pack.
one trick is to charge it (if it is 500AR sized) with 3A and fly right after the charger peaks. battery must be 40-45C if you are to get some performance out of it. this procidure might give you an extra 30% power boost.
hope this helps.
hope this helps.
