Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
HobbyZone SuperCub turning problems
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 11-08-2011, 08:13 PM
M9cat
Default HobbyZone SuperCub turning problems
Its been awhile since i posted here,anyway I have a hobbyzone supercub lp 3 channel and the darn thing is just hard to turn,bank or pull out of a right handed turn..It dosnt respond at all to the rudder movenment..I guess im asking what is better to have it turnable or manuverable with more tail weight or more nose heavy? Its like the rudder yaw has no effect but a little, the rudder is able to move both ways to where it just about touches the elevator..Any help on why i cant turn much or pull out of a turn more rapidly..Thank you!
Old 11-09-2011, 05:09 AM
whitecrest
whitecrest's Avatar
Default RE: HobbyZone SuperCub turning problems
Your wing may not have enough dihedral to translate yaw (created by the rudder) into wing banking. In this case, the plane will just slip sideways through the air after a heading change. If possible, try to increase the wing's dihedral angle (V) to make rudder turning more responsive. An alternative is to consider adding ailerons. You will definitely improve turning response with this modification.
Old 11-09-2011, 02:41 PM
M9cat
ok thank you, will try and adjust
Old 11-12-2011, 02:23 AM
M9cat
it was the dihedral of the wings...not enough V
thank you whitecrest
Old 11-12-2011, 06:17 AM
whitecrest
whitecrest's Avatar
Good job! I'm glad you got it flying properly. I had experienced the same problem with one of my scratch-built planes. The dihedral angle was set at only 3-4 degrees, and rudder turning was terrible. One of my earlier ships, a Gentle Lady, had polyhedral wings and had excellent rudder turning.
Good luck with your future flights!
Old 11-12-2011, 01:32 PM
cyclops2
cyclops2's Avatar
M9cat
Thanks for taking the time to post what did correct your problem. That will help others. Wish more people would do that.
We learn from others.
Rich
