Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Motor trouble
Old 11-30-2011, 02:08 PM
ejc34710
Default Motor trouble
Heya fellas, hoping for a little help here. I have a 24inch flying wing (speedwing) powered by an E-flite pro 25 amp ESC, SFM 20x40mm 4700kv inrunner, GWS 4x4 prop, with a Thunder Power 850mah 3s 45c. I think i may have fried the motor but not sure. It quit working mid-flight last time i flew it and it wouldn't spin after that, just kinda pulsate around. I smacked the motor shaft lightly with a screwdriver handle and it started working again. Went out to fly it, and it did the same thing. I can still hit the shaft to get it working but it quits shortly after again, usually when i give it over 50% throttle. I know i was pulling too many amps (around 31ish i think, motor rated at 25) so i'm pretty sure i fried the motor but wanted someones advice as to whether or not they know for sure. Already have an E-flite 20x40mm 4200kv inrunner ordered at my LHS (which will get the amps down to around 25) but just wanted to make sure it was the motor, not the ESC. You guys ever hear of anything like this before? Thanks for any help.
Old 11-30-2011, 03:29 PM
cubaneight
Default RE: Motor trouble
One or both motor bearings jamming perhaps? Sounds odd that the motor runs ok for a while after you tap the shaft. Are you able to turn the armature by hand when the problem occurs? If you can - probably shorted windings.
Hope this helps
C8
Old 11-30-2011, 07:12 PM
ejc34710
Yea, after the motor starts acting up i can still spin the shaft by hand. It is as if there wasn't anything wrong. But it kinda flips the prop back and forth sporatic-like when it's acting up and i give it juice. The ESC gets warm/hot too.
Old 11-30-2011, 07:14 PM
ejc34710
I might add that the motor and ESC are brand new. They have had less than 3 flights through them. Actually, they worked fine up until the begining of the 3rd flight, when the motor quit and showed the symptoms listed above.
Old 12-01-2011, 06:51 AM
Glacier Girl
Glacier Girl's Avatar
The cogging back and forth is a sign of an open winding, could be something as simple as a cold solder joint, or a broken winding inside the motor. The motor when it cogs like that is showing that one of the legs is not working and the motor can't decide what to do, creating a dead short, and why the esc is getting hot. You'll eventually let the magic smoke out of the esc and motor if you keep running it like that.
Is the set up letting good airflow to the motor? I would think if the motor is rated for 25 amps and your set up pulling 31, you should have been OK with good airflow and throttle control.
Check all your solder joints and the 3 legs on the motor for continuity.
I used to pull 50+ amps out of Mega's, rated at 23 amps in my Strykers and NEVER had an electrical failure. But on those the motor sat out in the airflow.
Old 12-01-2011, 08:55 AM
ejc34710
Yes, the motor sits completly out in the open. The ESC gets lots of airflow as well. Guess i bought a junk motor. 60.00 bucks for 2.5 flights, last time i ever buy a "Super Flying Models" product again. Thanks for the help though.
