Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
St Model Fox EP Problem w/Power System after Crash _Plz Help !
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 03-26-2012, 07:16 AM
VictoryRoll
VictoryRoll's Avatar
Default St Model Fox EP Problem w/Power System after Crash _Plz Help !
Hi All,
I have an St Model Fox EP, which can be found here:www3.towerhobbies.com/cgi-bin/wti0001p
I took her out on a very windy day and proceeded to have a short but memorable flight... nosed-dived straight into ground... Frankly, I believe mysetup(esp. elevevator or CG) was way off.
Although the crash did not do a whole lot of damage toofuse, etc., the motor mount was cracked in which I proceeded to make a new one (I have all dimensions if someone would like/need).
Put motor back in, and tried to run without success. Basically the motor, when applying throttle, just wiggles back and forth a bit and stops. Bring throttle to off, then reapply throttle, does the same quivering of the prop w/ no real revolutions on the prop/motor.
I tried to check if theESCbrake was on, but to do that, I need to "hear" one or two beeps after power/battery connected, which I do not... nothing.. no beeps whatsoever. Just the twitching of the prop. Without the beeps, I cannot tell if brake is on, so I followed procedure for turning the ESC brake OFF and ON, and off and on.. etc. Same result.
What do you suppose is the problem? The ESC gone? The motor broken? I have no idea, as this is my first electric powered aircraft.
Any help and/or suggestions would be greatly appreciated, as I do not want to replace parts just at random w/o knowing what specifically should be replaced and why.
I thank you in advance for your time and help.
Don
Old 03-26-2012, 07:58 AM
jzrf6c
Default RE: St Model Fox EP Problem w/Power System after Crash _Plz Help !
check for a broken/loose wire from the motor to the ESC. I've found that I get this indication when one of the connection is bad.
Old 03-26-2012, 08:03 AM
VictoryRoll
Thanks jz... I appreciate it.. I will try it out today
Thanks again,
Don
