Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Electrifly AMMO 28-45-3600 info
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 11-26-2012, 03:27 PM
FLYBOY
FLYBOY's Avatar
Default Electrifly AMMO 28-45-3600 info
I am trying to find out what that motor will lift. I can't find any info on how heavy of a plane it will take and I am new to electrics. I have a few, but just use what the kits call for. I have 2 gliders I want to put power on. The first is an old windrifter 118 inch wing and won't take much. Had an old graupner in it but fried it. The other is a 140 inch flat wing glider with glass fuse and foam wing. Its heavy though.
Any idea on the best motors to use? Thanks for the help!
Old 12-08-2012, 07:35 PM
Dr Kiwi
Default RE: Electrifly AMMO 28-45-3600 info
Being pedantic, that motor can't lift anything.. but with the prop you fit to it, it can be made to lift a decent amount. Realistically that is a 400W-450W motor so, depending on how much flight speed you need, if you gear it correctly, (say 5.5:1) you should be able to get it to spin about a 13" prop. For large gliders like yours, my feeling is you may need a heavier motor than 133g.... but that's beyond my area of expertise.
24-45-3600 is not in motocalc.
Motor: Great Planes Ammo 24-45-3790 (#5185); 3790rpm/V; 1.7A no-load; 0.0221 Ohms.
Battery: Thunder Power TP4400 (G4 ProPower 45C) (45C); 3 cells; 4400mAh @ 3.7V; 0.002 Ohms/cell.
Speed Control: Castle Creations Phoenix 60; 0.0012 Ohms; High rate.
Drive System: Direct; 13x8 (Pconst=1.17; Tconst=1) geared 5.5:1 (Eff=80%).
Airframe: Anything you want.
Motor Amps = 40.1
Motor Volts = 10.8
Input (W) = 434.0
Motor RPM = 36878
Prop RPM = 6705
Thrust (oz) = 65.4
PSpd (mph) = 50.8
