ZIPPY Compact 4000.
Hi
alis902.
I purchased a 4000. ZIPPY Compact.
I do not know how to charge because there is no manual.
Two (four mouth, mouth piece 3) there is a balancer code.
Do you charge separately?
Please let me know.
The charger you have the EOS0720i Net3 AD.
alis902.
My Feedback: (325)
The two balance taps must be plugged in (in the correct order) to use balance feature of any 7s charger along with the main leads. This may require a series balance board or adapter.
My Feedback: (325)
You will need an adapter to use the pictured board. Or you can perhaps re-wire the pack with the single connector. Or you can perhaps buy a series board that will work with a 3s and 4s pack. Ultimately it has to be wired according to this diagram. http://www.scriptasylum.com/rc_speed/lipo.html
